Ethernet connection & Password
- Ethernet connection & Password
09-02-2018 10:00 AM
In a recent post regarding a ethernet connection to a TV someone mentioned a password was only required if it was a wifi connection is that correct ?
I ask because I have a internet radio connected direct to the modem via a ethernet cable but it was necessary to enter the modem password before it would connect.
Re: Ethernet connection & Password
09-02-2018 10:03 AM
@gleneagles yes password is only for the WiFi
My TV and sons PS4 connect via homeplugs without any passwords
09-02-2018 12:30 PM
There are two modem/router passwords. One is exclusively for wireless and the other gets you into the admin pages. So which did the radio require? Has it also got a wireless interface that you aren’t aware of? Try disconnecting the Ethernet lead and see if it still works.
