Ethernet Switch
- Ethernet Switch
Re: Ethernet Switch
23-12-2017 9:54 PM
Re: Ethernet Switch
23-12-2017 9:54 PM
I think the fault probably lies in either the the long cat5 or the switch.
Can your PC ping your router?
All devices will need to see the router.
Re: Ethernet Switch
23-12-2017 9:57 PM
Are you able to carry your PC downstairs & plug it in with a short ethernet to your router?
Re: Ethernet Switch
23-12-2017 10:09 PM
just plugged long cat5 straight into pc, internet works, its what im using to post this.
Re: Ethernet Switch
23-12-2017 10:15 PM
Re: Ethernet Switch
23-12-2017 10:19 PM - edited 23-12-2017 10:19 PM
ipv4 192.168.1.67
sub net 255.255.255.0
default gateway 192.168.1.254
Re: Ethernet Switch
23-12-2017 10:27 PM
It's likely the switch, then. [I assume the connections were in properly].
Peculiar, because they are normally very reliable.
I assume that you checked the lights on any ethernet ports when it wasn't working.
Re: Ethernet Switch
23-12-2017 10:32 PM
Re: Ethernet Switch
23-12-2017 10:40 PM
all plugs in fully, all lights correct, other two devices can access internet just not pc. i'm going to go buy a new wifi adapter tomorrow, see if that fixes pc problems. current built in wifi keeps dropping connection not sure if its its hub1 or pc.
Re: Ethernet Switch
24-12-2017 2:04 AM
Why are you using wifi for the PC?
Re: Ethernet Switch
24-12-2017 8:51 AM
i've used WiFi for the pc because i only have the one ethernet cable running upstairs that i split for the bluray and skyq. but i'm having trouble with the WiFi on the Hub1 slow speeds and constant dropouts. so i was wanting an ethernet connection for the pc too.
If i put my laptop beside the hub1 on WiFi i'm only getting 7mbps download and 6mbps upload, i have no idea why. Upstairs on the pc i get 12mbps download but it keeps dropping out.
Re: Ethernet Switch
24-12-2017 10:07 AM
Re: Ethernet Switch
24-12-2017 10:18 AM
@celica2012 - Can I suggest that you turn off all of your connected devices, the PC, BluRay and SkyQ and the switch as well.
You might want to take this opportunity to reboot the router while these devices are off. Once the router has restarted turn the devices on starting with the Switch, then the attached devices in any order you want.
Having done this chances are it will all work for you as intended.
Networks can be fickle things, and I've found in the past that this approach is an option that works.
Re: Ethernet Switch
24-12-2017 10:47 AM
I've fixed it. I've run a second Ethernet cable upstairs so the pc has it own connection straight to the router. Pc now has 45mbps download, the switch then works the BluRay and SkyQ.
Thanks for all the suggestions, Merry Christmas and a Happy New Year!!!!
Re: Ethernet Switch
24-12-2017 11:01 AM
This is more like treating the symptom and not the cause. So if you can be bothered, and have the 5 minutes to space you might want too try what I suggested above. I've been there and done that, I know it sounds odd but so is life.
