Essentials XP issue?
- Essentials XP issue?
16-04-2014 11:17 PM
Re: Essentials XP issue?
16-04-2014 11:36 PM
Open up
msconfig.exe =======> untick all the Startup items
Reboot into normal mode ======> if boots up ok =======> Re-tick the Startup items one at a time to see which is causing the issue(s)
17-04-2014 6:12 PM
19-04-2014 8:41 PM
Quote from: TORPC When it boots up in safe mode
Open up
Tried this switching everything off with no success.
When I can get window to start up normally, I get a message about my active desktop not starting correctly.
I say when, because now I can only get Windows to start in Safe Mode. And even with Safe Mode and Networing selected I cannot connect to the Internet. Concerned I may have a Hardware problem after all
21-04-2014 7:22 PM
- Computer becomes very slow, possibly taking an hour or more to get past the Welcome screen
- Error messages that Microsoft Security Essentials (or a component thereof) is not working
I fixed this by booting to Safe Mode and using msconfig to block all startup programs and non-Microsoft services.
Re-starting normally and uninstalling MSE.
Installing MSE version 4.3 or 4.4 (then blocking the 4.5 update to avoid the scare-mongering messages).
P.S. The 'fix' issued by Microsoft is unlikely to work without intervention because affected computers don't perform well enough.
23-04-2014 6:41 AM
23-04-2014 9:28 AM
Boot to safe mode, in Computer Management change the Microsoft Antimalware process to manual and stop it.
Reboot to normal mode, open IE and download and run the latest standalone virus definitions for MSE (self-install pack) and restart MSE from within itself.
This seemed to changed the process properties back to normal so no further action was required.
Can't recall exactly where the MSE definitions are but Google found them quickly (on the Microsoft web site).
23-04-2014 2:32 PM
Start the computer in Safe Mode with Networking (probably only works with a wired network connection).
Start MSE and Update it. The update reports an error during installation but ignore that.
Restart in normal mode; MSE now reports it is up to date and works normally.
Edited to correct misprint
23-04-2014 2:37 PM
23-04-2014 3:52 PM
Now in the case of MSE antivirus it may not provide full protection but the updater appears to work
24-04-2014 7:49 PM
I gave up (Enough of seeing the pop up message as well) and went out and purchased Windows 7. Installed now and works fine.
I have another desktop running XP which interestingly doesn't have the issue. If it does, I will try the suggested fixes.
Out of interest, the final straw was that I could not start XP in normal mode (to see if it would lock up again). No matter what I selected, XP would start in Safe Mode. After a number of Safe Mode start ups does XP only start in Safe Mode?
24-04-2014 11:39 PM
XP does not get stuck in Safe Mode unless you choose the Diagnostic Startup option in msconfig then forget you did it.
