Errors on ethernet
createdbydan
Errors on ethernet
Having tried numerous cables and other laptops im seeing a lot of errors on the ethernet ports. eth0 is the WAN port to the OR modem..
Interface
Received
Transmitted
Bytes Pkts Errs Drops Bytes Pkts Errs Drops
eth0 3013906 5537 16477 0 2302539 9809 0 0
eth1 229894576 450995 9393 0 876368354 935690 0 277
eth2 2147483647 4808041 1848 0 1168779097 5713085 0 1144
wl0 387049931 2272059 0 0 2147483647 5760650 0 0
Any ideas?
3 REPLIES 3
createdbydan
Re: Errors on ethernet
Also,
If I restart my PC, it thinks its connected to the internet but it isnt, Nothing works.
If I unplug and plug back in the cable at the PC end there is no change.
If I do the same at the router, it works, but only (and usually unsuccessfully) if I plug the cable into a different port than before.
Makes it a nightmare when then PC reboots when I am away and need to remote desktop to it.
createdbydan
So tonite.. I have bought lottery tickets, want to know why?
ALL THREE of the cables I tried turned out to be faulty.
I made my own and now my speed test results are 69/18
So happy right now haha
7up
Fixes: 17
Stranger things have happened at sea!
