Error message
Error message
I just recovered from a hard disc failure.
It wasnt registering in the Bios so I checked the HD on another computer via a caddy.
It was being read ok so I backed up the data and tried putting it back in its machine.
This time it fired up ok
I ran the full chkdsk program for good measure
The only problem now is repeated interruptions by an error message:
Microsoft .NET Framework
An unhandled exception has occurred in your application. Click continue and application will ignore this error and attempt to continue.
When I click on details I get the following. I see some guidance at the end but haven't quite figured out where I need to go to to insert the code or wether there are other things I must do as well
Can anyone please advise?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: File or assembly name Accessibility, or one of its dependencies, was not found.
File name: "Accessibility"
  at System.Windows.Forms.Control.OnHandleCreated(EventArgs e)
  at System.Windows.Forms.Control.WmCreate(Message& m)
  at System.Windows.Forms.Control.WndProc(Message& m)
  at System.Windows.Forms.Label.WndProc(Message& m)
  at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
  at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
  at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
=== Pre-bind state information ===
LOG: DisplayName = Accessibility, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
(Fully-specified)
LOG: Appbase = C:\Program Files\HP\Digital Imaging\bin\
LOG: Initial PrivatePath = NULL
Calling assembly : System.Windows.Forms, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b77a5c561934e089.
LOG: Attempting download of new URL file:///C:/Program Files/HP/Digital Imaging/bin/Accessibility.DLL.
LOG: Attempting download of new URL file:///C:/Program Files/HP/Digital Imaging/bin/Accessibility/Accessibility.DLL.
LOG: Attempting download of new URL file:///C:/Program Files/HP/Digital Imaging/bin/Accessibility.EXE.
LOG: Attempting download of new URL file:///C:/Program Files/HP/Digital Imaging/bin/Accessibility/Accessibility.EXE.
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.2407
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
hpqimzone
    Assembly Version: 3.0.0.0
    Win32 Version: 065.000.117.000
    CodeBase: file:///C:/Program%20Files/HP/Digital%20Imaging/bin/hpqimzone.exe
hpqiface
    Assembly Version: 4.0.0.0
    CodeBase: file:///c:/windows/assembly/gac/hpqiface/4.0.0.0__a53cf5803f4c3827/hpqiface.dll
    Win32 Version: 1.1.4322.2032
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
hpqcc2
    CodeBase: file:///c:/windows/assembly/gac/hpqcc2/3.0.0.0__a53cf5803f4c3827/hpqcc2.dll
hpqutils
    CodeBase: file:///c:/windows/assembly/gac/hpqutils/4.0.0.0__a53cf5803f4c3827/hpqutils.dll
hpqfmrsc
    CodeBase: file:///c:/windows/assembly/gac/hpqfmrsc/4.0.0.0__a53cf5803f4c3827/hpqfmrsc.dll
hpqtray
    CodeBase: file:///c:/windows/assembly/gac/hpqtray/4.0.0.0__a53cf5803f4c3827/hpqtray.dll
hpqovskn
    CodeBase: file:///c:/windows/assembly/gac/hpqovskn/3.0.0.0__a53cf5803f4c3827/hpqovskn.dll
hpqthumb
    CodeBase: file:///c:/windows/assembly/gac/hpqthumb/3.0.0.0__a53cf5803f4c3827/hpqthumb.dll
hpqimvlt
    CodeBase: file:///c:/windows/assembly/gac/hpqimvlt/3.0.0.0__a53cf5803f4c3827/hpqimvlt.dll
hpqimgrc
    CodeBase: file:///c:/windows/assembly/gac/hpqimgrc/4.0.0.0__a53cf5803f4c3827/hpqimgrc.dll
System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
hpqntrop
    CodeBase: file:///c:/windows/assembly/gac/hpqntrop/4.0.0.0__a53cf5803f4c3827/hpqntrop.dll
Interop.hpqcxm08
    Win32 Version: 70.0.170.000
    CodeBase: file:///c:/windows/assembly/gac/interop.hpqcxm08/3.0.0.0__a53cf5803f4c3827/interop.hpqcxm08.dll
LEAD
    Assembly Version: 13.0.0.113
    Win32 Version: 13.0.0.113
    CodeBase: file:///c:/windows/assembly/gac/lead/13.0.0.113__9cf889f53ea9b907/lead.dll
LEAD.Wrapper
    CodeBase: file:///c:/windows/assembly/gac/lead.wrapper/13.0.0.113__9cf889f53ea9b907/lead.wrapper.dll
LEAD.Windows.Forms
    CodeBase: file:///c:/windows/assembly/gac/lead.windows.forms/13.0.0.113__9cf889f53ea9b907/lead.windows.forms.dll
LEAD.Drawing
    CodeBase: file:///c:/windows/assembly/gac/lead.drawing/13.0.0.113__9cf889f53ea9b907/lead.drawing.dll
hpqasset
    CodeBase: file:///c:/windows/assembly/gac/hpqasset/4.0.0.0__a53cf5803f4c3827/hpqasset.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
4 REPLIES 4
Re: Error message
Could be worth uninstalling the Microsoft .NET framework the reinstalling it to see if it cures the problem.
You can uninstall it via Add/Remove Programs, and if you want to re-install it you can get the latest version from the Windows Update website (Run custom scan, then look in the optional components section to find it.)
Re: Error message
Thanks for that
It sounded like a good solution only it wont work
There are 3 .net programs listed there
Net 1,  Net 1 hotfix and Net 2
Whichever one I try to uninstall it starts the uninstall process and then the error message pops up and prevents it from continueing
I try to close the error message but then the uninstall cancels itself.
This happens each time
Is there some way of disabling the error message?
Re: Error message
Hmm, I wonder if installing the latest version over the top might fix the issue.
You can get version 3.0 here: http://www.microsoft.com/downloads/details.aspx?FamilyID=10cc340b-f857-4a14-83f5-25634c3bf043&Displa...
Looking at my machine, each subsequent version has been installed without uninstalling the previous version.
Its a grasp at straws really, but you never know...?
Unless somebody has a better idea of the problem and solution.
Re: Error message
Try running the repair installation for your HP printer - it seems that's what is causing the problem.
B.
