Error Message "Can't Access X workgroup"
- Re: Error Message "Can't Access X workgroup"
12-06-2009 9:11 AM
I have tried to set up a wireless LAN between my desktop and laptop computers. But I am having difficulty getting them to "talk" to each other. Both connections are excellent on both computers. The only difference between the two computers is that on the laptop, when I view the workgroup computers, both computers show up on the laptop. However, they don't show up on the desktop. I also get an error message " Can't Access X workgroup, where X is the name I have assigned to the group.
Has anybody had this problem, and how do they get over it.
3 REPLIES 3
12-06-2009 9:13 AM
It could be firewall related on your desktop, try turning any software firewall off and try it.
If it works you know that is your problem
12-06-2009 9:24 AM
Thanks for your quick response adiewoo.
However, I thought that, so I set up the firewall profiles on both computers to be the same. I have AVG Internet Security on both.
12-06-2009 2:23 PM
Are they both in the same workgroup? Can you ping the other machine. What is the router on some routers you cant connect 2 wireless pc's without setting it up on the router
