Erase pics after download from SD card
- Erase pics after download from SD card
21-03-2014 12:53 PM
Is there a similar prog with Linux?
First time inserting my card. I only get the choice of importing with Gthumb.... which is associated with Gimp,... which I don`t want to use....
I want to store my pics on a daily basis to dated folders in the Pictures ( or specified as " Digital Camera Downloads 2014") folder, and then use Irfanview for quick viewing and editing.
Don`t want to have to fuss about, doing 5 operations, when I used to do 1, before I can access/edit pics
Re: Erase pics after download from SD card
21-03-2014 2:11 PM
21-03-2014 5:28 PM
21-03-2014 5:57 PM
21-03-2014 6:04 PM
Not sure about auto-delete - but its easy to select those pictures/videos you want to delete off the card.
21-03-2014 6:06 PM
21-03-2014 7:38 PM
Have installed DigiKam..... no problem.... some quite interesting tools on that prog.... it will do as a replacement to Photo Pos Pro, which. I can get partly working... ( it freezes on the opening screen at " loading layers window " ) can`t seem to find a way around that...
Also installed "Rapid Photo Downloader"..... maybe not needed now...
Point of interest... how do I "uninstall" stuff on Mint 16 ..... if there isn`t an Uninstall .exe file .... do I just delete it from "program files" ?
Thanks.
21-03-2014 10:54 PM
You uninstall the package(s) used to install the programs.
Two varieties of this:-
A plain uninstall will leave any system settings used by the programs untouched (in the /etc directory)
A purge install will remove both programs and system settings.
I hope you installed things with a package installer?
If you downloaded the source code and compiled it, you have a lot of trouble.
22-03-2014 12:00 AM
Quote from: vilefoxdemonofdoom If you downloaded the source code and compiled it, you have a lot of trouble.
I really don't think @shutter's that mad.
22-03-2014 8:13 AM
22-03-2014 9:16 AM
Quote from: 77
Or that clever !
