End of vista support
- Re: End of vista support
14-04-2010 11:39 AM
am i right in thinking that vista sp2 is still supported
14-04-2010 11:42 AM
14-04-2010 11:47 AM
shhh. dont tell the other half its still got a years life left in it.
14-04-2010 12:00 PM
Still the more people upgrade the more ££££ to them
14-04-2010 12:01 PM
14-04-2010 12:24 PM
Maybe not ......but they should have
14-04-2010 1:50 PM
any one hit any pitfulls using the upgrade version on a vista machine
14-04-2010 2:20 PM
Quote from: Hairy Another way of pushing W7 ? Since a lot of users are still on XP why ?
I have still got my old XP install disc..... and the SP3 disc.... so could go back in time.!.....
alternatively.... keep Vista running until it fails. meanwhile start to learn Mint 8 Helena et al ! ! !
14-04-2010 2:51 PM
Quote from: Asbo any one hit any pitfulls using the upgrade version on a vista machine
No not really. In fact it was all very trouble free, and cured a couple of issues I was having with Vista, that have not carried over to Win 7 as some thought it might. I rather like that "glass" effect to window edges, indeed I've set them slightly wider than the standard.
14-04-2010 5:52 PM
X.P. is dead as a dodo and well past its sell by date, Linux is alright, But for full capabilities and to unlock your pc's true potential it has to be Windows 7, Its just great in every way, In saying that windows 8 will be forced upon us in the not to distant future and theres already a windows 8 forum started up!!
14-04-2010 6:29 PM
It's now a dual boot Windows 7 / Ubuntu laptop now
Windows 7 is crap.
14-04-2010 6:30 PM
Also if its that crap then why are you dual booting
14-04-2010 7:29 PM
I left the Windows system intact, together with its rather manky NTFS file system; this was because:-
a) I've still got nearly 2 years left on a free support contract.
b) Officially it's not "mine" as my daughter has requisitioned it and she prefers the free M$ solitaire game to the free Ubuntu solitaire game...
c) I paid all that money for an OS I don't want...
d) I enjoy making sure that the anti-virus is updated regularly and slowing the PC down (hence the 64 bit dual-core).
e) I love defragmentation...
f) You get more updates to apply with M$ - although it mostly doesn't say why something should be patched (if it doesn't, I don't do it).
g) You get lots more screensavers with Ubuntu
h) Ubuntu is faster
i) There is no (i) - yet!
14-04-2010 9:19 PM
Quote from: A Sorry - please refer to http://fullcirclemagazine.org/issue-8/ Wubi (in relation to Windows)
I found that AisleRiot Freecell version was very similar to the M$ one.
14-04-2010 9:54 PM
Quote from: Steve Well i dont know how much an upgrade costs
Without digging out the receipts I think it was about £65 for the single licence version from Staples (which I usually find are very reasonable for software, if a bit short on product ranges)
