End Process vs End Process Tree
Mav
Fixes: 518
Occasionally I have to resort to using End Process to recover from a program crash or when it seems to be 'stuck'.
But what is the difference between End Process and End Process Tree? I have tried both and can't tell any difference in action(s) taken apart from the program quitting and able to be restarted.
Forum Moderator and Customer
3 REPLIES 3
Re: End Process vs End Process Tree
When an application starts up it get a Process ID (PID) this process can of course spawn other processes and it is this these processes that make the process tree. When you kill the process you can leave others dangling which can have adverse effects. But if you kill the process tree all sub processes spawned by the primary process are killed first with the main PID killed last. If you are in any doubt use kill tree.
Mav
Fixes: 518
I kinda thought that would be the answer. I tend to use End Process Tree most of the time anyway.
Thanks.
kmilburn
If you use a decent task manager like Process explorer,  it'll show you the process tree too.
