Do you mean
Enabling QoS on Hub Zero 2704n?
Member
Hello
I was hoping someone could help me in enabling QoS on this router?
Previously I used other routers and they had QoS by default, but this one seems to have it turned off with no way to enable with the interface.
As a result I need to keep my phone off wifi while using laptop or suffer extreme rubber banding.
I called plusnet but they told me to ask here instead as this isn't something they would do due to security risks etc?
I read the long thread on unlocking the potential of 2704n but unfortunately didn't understand a huge amount and appeared outdated with firmware.
Thanks in advance
