Enable Ports
aoluokun
Enable Ports
Can someone pls tell me how i can check if some ports are enabled on my broadband service. the ports are 50, 500, 4500, 123
Fixes: 81
Re: Enable Ports
Welcome to the forum aoluokun.
Try https://www.grc.com/x/ne.dll?bh0bkyd2
Customer and Forum Moderator.
Fixes: 62
Re: Enable Ports
you need to go to here and select Shields Up http://www.grc.com/default.htm
Aubs
Re: Enable Ports
Plusnet don't block *any* ports, though if you've got the Broadband Firewall turned on, you might find some ports inaccessible from the outside world.
You can check your Broadband Firewall status by logging into the member portal here:
https://portal.plus.net/my.html?action=firewall
