Embedded link query
- Embedded link query
Embedded link query
09-07-2014 4:48 PM
If I click it I am presented with a single pixel page with this URL
http://cj.dotomi.com/8b103ar-zH/ry2/GFKFIFHO/LGJLOMN/F/F/F?s=u4up%3DDKJpt59oGDEm2%2663x%3Dt551%25FM%25ER%25ER888.mp0nq.o0y%25ER40r58m3q%25ERrxm4t%25ERmn065%25ER%3C%3Ct551%3A%2F%2F888.p1n0x78.zq5%3AKC%2Foxuow-IDGILJK-DCHCFCEL%3C%3CS%3C%3C
I have had this on other links, often Google search results with the same results.
I'm running Waterfox 30.0 and have the same issue in Chrome.
Anyone any ideas?
Re: Embedded link query
09-07-2014 5:52 PM
09-07-2014 6:59 PM
I went through that procedure earlier today dvorak but nothing showed up in registry or elsewhere.
09-07-2014 7:50 PM
09-07-2014 10:17 PM
10-07-2014 7:46 AM
If you hover your mouse over an embedded link you should see what URL is embedded (at the bottom of the screen, typically). If you click on the link and end-up somewhere else that is a symptom of some sort of DNS changer, malware that redirects your DNS queries to a corrupt server of its own choosing. One way of achieving this effect, although out-of-fashion at the moment, is to change your settings under Internet Options - Connections - LAN settings to make you use a Proxy Server. So that is always worth checking under these circumstances.
10-07-2014 8:03 AM
http://www.trendmicro.co.uk/products/free-tools-and-services/
10-07-2014 10:23 AM
You can either dragndrop or copy / paste the results from the notepad logged window into it
10-07-2014 11:38 AM
Kaspersky rescue disc created.
Looks like the Kaspersky rescue disc scan is going to take some hours so unfortunately I have to cut the hedge
10-07-2014 12:18 PM
Edit: In fact if you copy the Autoruns result here I will tell you which entries are suspect.
10-07-2014 7:03 PM
10-07-2014 7:20 PM
10-07-2014 7:31 PM
I'm heading for a complete reinstall in the not too distant future for a number of reasons.
Thanks very much for everyone's contributions.
10-07-2014 10:24 PM
Quote from: Strat a quick Google of the unknown ones revealed no nasties.
Yes, but if a Google search gave a result then it's almost a given that your security software would detect it also. What you are looking for is something so new that it is unknown and passes undetected. Typically Lexmark are lax with getting their printer drivers signed, there is (incredibly) an unsigned component of the Trusteer Rapport software, often the odd unsigned codec. Anything else is suspect.
10-07-2014 10:59 PM
try this
http://computervirusmanualremval.blogspot.co.uk/2014/05/remove-browser-hijacker-cjdotomicom-how.html
