Embarrassing Question
Oldjim
Fixes: 63
After the last system Plusnet failure my autologin doesn't work and I can't remember how to set it.
Jess was no help as you would expect
2 REPLIES 2
spraxyt
Aspiring Legend
Fixes: 75
Re: Embarrassing Question
Is this what you need? Not sure if you need to remove the existing cookie first.
David
David
Oldjim
Fixes: 63
Yes it is - I missed your post but found it using Google
However - I don't see how I couldn't see this from my standard link to the member centre  Embarrassed Embarrassed
