Emailing Pics
- Emailing Pics
Emailing Pics
18-07-2009 12:29 PM
Re: Emailing Pics
18-07-2009 2:16 PM
edit, just added the text in LH corner with IrfanView
Re: Emailing Pics
18-07-2009 2:53 PM
Re: Emailing Pics
18-07-2009 3:57 PM
if you go into more complex edit progs, they use what are called layers, you could make a layer with your sig on it, save it then paste it as a new layer onto the original pic and post that
Re: Emailing Pics
18-07-2009 4:09 PM
http://www.v3.co.uk/computeractive/downloads/2164817/paint-shop-pro
for those who want a slightly simpler program to get used to than gimp first appears to be that adds text to photos & a lot more it's probably worth a punt
-- only minus I've found is a prompt when you close the program to buy the latest version, I've still to find how to disable it.
Re: Emailing Pics
18-07-2009 4:10 PM
Re: Emailing Pics
18-07-2009 4:15 PM
Re: Emailing Pics
20-08-2009 10:33 PM
Re: Emailing Pics
21-08-2009 8:27 AM
get the pic on the screen in irfanview.
make a selection box on the picture by "left click and hold" the mouse cursor. in the approx position you want the text to appear
go to Edit (top tool bar) and click "Insert text into selection"
You now get a box with a menu of choices....
type your text into the white box.
check the little box underneath with a tick (Text is transparent)
choose the font (as in normal text operations .... including size and colour)
choose the location in the "selection box on the pic" where you want the text (centre is good)
then click OK...
if text is too big or too small or wrong colour, for the box, go back to choose font and reset.
When happy with the result..... don`t forget to go to File and Save....... (use same file name but add a letter or number, and it will save it in the same directory as the original.....
As a point of interest. this text will remain in the box until you change it... so next time (if you haven`t used the facility of adding text, it will still be the same, (you will still need to locate the selection box at the start of the program when you use a new pic..
Irfanview is SIMPLE to use, and of course FREE......
hope that helps
Re: Emailing Pics
21-08-2009 8:35 AM
