Email on Kindle Fire wi9th Plusnet and O E
stathe
Outlook express was woking O.K on my Kindle Fire  but  now  I am unable to receive  though .I can send,    I have set my password then ----- imap.plus.net  -- Security none------ Port 143
It says E mail adress or password incorrect      Any advice apreciated      My O.E express on my main computer is set POP 3 and leave message on server Why should thiis sudenly fail  Thank You
2 REPLIES 2
spraxyt
Aspiring Legend
Fixes: 75
Re: Email on Kindle Fire wi9th Plusnet and O E
The entry in the account name box that appears on the same screen as where the account password is entered should contain only your account name (the same one you use to login to the Member Centre). This is NOT an email address. Have you entered that correctly?.
David
stathe
Thanks,I did have it wrong my user name being where I live and not my name  Thanks again
