Email account only
BB
Email account only
I have just left Plusnet
I have set up an Email only account.
I can receive emails fine, but I am unable to send any. error message 505 comes up
I spoke with technical who were helpful. I can send emails on webmail but not on any other , ie thunderbird or bluemail
Help me please !!!
6 REPLIES 6
Fixes: 339
Re: Email account only
Error 505 is 'client not authenticated'
When not sending from a plusnet broadband connection , you must use authentication for the outgoing server with your plusnet username and password
BB
How do I do this . I have tried various but its not happening on Bluemail or thunderbird
Fixes: 339
When configuring the outgoing server there should be an option ( certainly is on tbird) 'use authentication'
Select that and use your plusnet account and password as the username and password required by the authentication configuration
BB
Will not work on tbird. I have sorted bluemail
Fixes: 339
It will work on Tbird. I use it on my tbird configurations, I just don't have them to hand to show the details at the moment. I'm away from home and only have android tablets using k9 with me.
Mav
Fixes: 510
Moderator's note(s):
Thread moved from General Chat to Tech Help.
Forum Moderator and Customer
