Effect of my neighbours 2-stroke strimmer
- Re: Effect of my neighbours 2-stroke strimmer
27-08-2009 8:16 PM
I couldn't think where to put this but I thought it might be of interest - the effect of the 2-stroke engine on my error rates
2 REPLIES 2
27-08-2009 8:22 PM
small garden if it only took them 1 minute to do
good detective work there oldjim does it not show up even the slighest on the snr then?
27-08-2009 8:30 PM
Scale is hours and minutes not minutes and seconds
Not a sign of it on the noise margin though although there was a limited amount of bit swapping
