EXIF tag info in an iPad image file
journeys
Any one know how to extract this information
I've tried Irfanview but it does not show (Image>properties>EXIF)?
AM I missing something?
8 REPLIES 8
Re: EXIF tag info in an iPad image file
shutter
Fixes: 64
Image > (drop down menu -- at the top )... Information.....  opens new window.... bottom left is Exif Info*  Click on that, and all will be revealed.  ! ! ! ..
journeys
@shutter, thanks got that far but  EXIF gps field are not available (no location), the iPad is GPS enabled and reports to be recording the location in the image.
I'm guessing the iPad is not working as it should.
shutter
Fixes: 64
ok... perhaps a search on Google  ? ?    something here may be useful
https://www.google.co.uk/#q=IPAD+EXIF+GPS+INFO
I assume your location services are turned on? I have mine off so if yours is the same then maybe it is not recording them because of your preferences. Just a thought.
@shutter - Where is this menu you're referring to?
shutter
Fixes: 64
Top Tool bar.... File...   Edit  .. Image...   Options....   click on Image and a drop down menu appears ... the first item is "Information"   click on that for the next menu... Exif info is at the bottom of that .
journeys
@Anonymous, thanks, yes location services are turned on.
It appears the EXIF information is not being recorded on the IPad.
journeys
Got it, as well as 'location services' I needed to indicate to the 'camera app' that I wanted to geotag (GPS tag) the images.
thanks guys
