E mail
andrus53
E mail
Roll eyes
1 REPLY
Fixes: 62
Re: E mail
Poll locked as it serves no purpose and doesn't even relate to the question.
If the poster wishes to raise the question again it should be under Community Support with a little more detail.
However if it is in relation to Webmail I believe you need to login to the mailbox and select Options then Display Preferences and then select Show HTML Version by Default. I think that will fix it for font colour etc. but not spell check. For spell check you should use Firefox with British English Dictionary added with "Spell checking as I type" enabled in Firefox Options, Advanced
