E mail links not working
- Re: E mail links not working
22-02-2010 4:37 PM
Help please I seem to have upset something as when I click on an email link I get the message "application not found"
5 REPLIES 5
22-02-2010 4:44 PM
Can you clarify.
When you say an email link is this a link on a website where they want you to send them an email and if so which browser are you using
22-02-2010 4:53 PM
Its both when clicking on a link to go to another item or website it says application not found .
When clicikng on an email link on a web site it says default email client not properly installed
22-02-2010 5:09 PM
Assuming you are using IE8 can you try with Firefox http://www.mozilla-europe.org/en/firefox/ as this will hopefully tell us whether it is a browser problem or something more serious.
A quick question - assuming you are using IE8 - have you been changing the security settings.
22-02-2010 5:28 PM
Thanks for your quick reply . It is IE 8. I have not knowingly changed any security settings.
Will try firefox as you suggest
23-02-2010 10:32 AM
Can you give us an example of a site which has this problem? We can try it ourselves as well, then.
