Duplicate file finder
- Duplicate file finder
18-05-2011 5:49 PM
I used to use a free program called Duplicate File Finder which worked well although it hasn't been supported for a few years.
It refuses to run under W7 64bit so I am now looking for a free alternative. Does anyone have any views on what's good or what's rot out there?
Forum Moderator and Customer
Re: Duplicate file finder
18-05-2011 5:56 PM
I haven't used anything like this myself but google brings up plenty of alternatives, Here's one I found, Don't know how good It Is though.
http://www.tucows.com/preview/604148
18-05-2011 6:00 PM
I'm concerned by the effectiveness of of them - I don't want to end up losing the the original file as well as the duplicates by using dodgy software that's why I was looking for some kind of recommendation.
I went through a similar process when I found the above-mentioned prog. Can't remember now what swayed me towards it.
18-05-2011 6:01 PM
Edit, Its 93%popular, Here Is a link to the site directly, Check It out. http://www.mindgems.com/products/Fast-Duplicate-File-Finder/Fast-Duplicate-File-Finder-About.htm
18-05-2011 6:14 PM
18-05-2011 6:53 PM
I've downloaded both to have a gander at.
The Auslogics Duplicate File Finder lets me down as you are limited to the filetypes you can search for or all which could take an inordinately long time to perform.
Fast Duplicate File Finder doesn't even let you choose filetypes without buying the pro version
WIth my previous program I was able to select any or multiple folders/drives, edit and add any filetypes I wished, restrict files sizes between two values and also could search for duplicate dates, file sizes, contents, etc. So was very powerful.
With thousands of photos (particularly) collected over years and spread over several drives the ability to restrict search criteria is very important to me.
Ah well, back to the serach
05-06-2011 7:33 PM
I perceveered with Auslogics Duplicate File Finder and it seems to do the job well.
Further searches found some good recommendations.
So, for now, I'm sticking with it
