Dunstone: The pirates will always win..
Fixes: 247
Interesting article..
http://www.guardian.co.uk/business/2009/jun/05/dunstone-carphone-warehouse-results-pirates
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
1 REPLY
Re: Dunstone: The pirates will always win..
The have won for years and always will do. How come they can crack windows copy protection before it even comes out unless MS are helping? Didnt Bill say no one will crack the copy protection and 1 days later they did it.
Dont tell me Adobe doesnt know that one very simple crack works for all their software. Pirates sell software as most buy it or recommend it. Its just like making it shareware so you can try before you buy. Maybe MS should let you try before you buy and in some way they have with sp3 xp you dont need to put in a key at the start.
