Downloading Youtube
penneck
Re: Downloading Youtube
Hello @RPMozley  I've just gone into File Hippo, and found a list of 'old' 4k Video Downloader versions, but only found a download, not an install. I tried the download in case it automatically went into install mode, but no. I may need some guidance, please
shutter
Fixes: 67
@penneck You can choose any of the version 19.x from this site
https://www.videohelp.com/software/4K-Video-Downloader/old-versions
scroll down the listings until you get to version 19...  then choose the  .msi version for downloading... on completion of the download, you just click on the file and it should "open and install" from there.. ( If I remember correctly)
penneck
Hello @shutter . I have just followed your instructions using the msi version of the file I wanted. It downloaded onto my pc into the 'User/Graham/Download' folder, so I clicked on it, and it installed properly. I have an icon on the Desktop, and 4kvideodownloader is on the Uninstall list under 'Control Panel/Programs and Features'. I have done a test music video download and it worked, so thankyou.
To everyone who got involved in this topic, your help is very much appreciated.
Regards to all
shutter
Fixes: 67
@penneck  Happy to help !.
Enjoy !
