Downloading PDF File
- Re: Downloading PDF File
07-01-2014 12:24 PM
This is driving me crazy. When I try to download any PDF document onto my PC it arrives in a miss/match of symbols and therefore I cannot print anything that is readable. Some one has got a simple answer to this, Please........Thanks.
7 REPLIES 7
07-01-2014 12:26 PM
Which PDF reader do you have installed as it sounds as though you are trying to open it in notepad or similar
07-01-2014 12:26 PM
You have installed a PDF reader, such as Adobe Acrobat, haven't you?
Geoff,
York.
York.
07-01-2014 12:53 PM
I would Right Click on the file you want to open, e.g. ending .pdf and select 'Open with' whatever program you have installed.
07-01-2014 1:52 PM
Yep have reinstalled adobe acrobat reader. Tried to move to drive same problem when I open it, someone told me its the font but. I don't understand this.
07-01-2014 1:59 PM
Let us try a roundabout route
Uninstall Acrobat Reader and then install PDF-Xchange Viewer and when it asks if you want it to be the default viewer for pdf files click on yes http://www.tracker-software.com/product/downloads
07-01-2014 2:03 PM
Or, right click on a PDF file, select 'Open with' then select 'Choose default program' and assign Adobe Acrobat!
Geoff,
York.
York.
07-01-2014 3:27 PM
Great, works a treat now. Have printed all my holiday travel documents. Thanks for all your help, could not have done it without you.
