Dont suppose anyone will know ?
- Dont suppose anyone will know ?
- « Previous
- Next »
Re: Dont suppose anyone will know ?
04-10-2010 4:04 PM
Thanks for the reassurance i feel i should know these things but i dont. with regard to xp the advisor told me that my pc supports hardware assisted virtulisation technology but it must be enabled in the system BIOS before running XP mode. So i presume once i have installed win 7 i alter my Bios sounds as easy as performing brain surgery on myself........... :-[.
04-10-2010 4:07 PM
I'm not sure how that works but someone here will be able to help you with that, We are all here to learn, I have learnt quite a bit with just this friendly forum alone.
Quote from: Fantasticfourum . with regard to xp the advisor told me that my pc supports hardware assisted virtulisation technology but it must be enabled in the system BIOS before running XP mode. So i presume once i have installed win 7 i alter my Bios sounds as easy as performing brain surgery on myself....
If life gives you lemons, make lemonade.
04-10-2010 4:09 PM
Quote from: Steve No I can run programmes In xp mode and I use windows 7 premium.
No, you'll be using a "compatibility" mode. Not the same thing, though very effective in many cases.
04-10-2010 4:11 PM
Doh your right HPsauce I stand corrected
![Embarrassed Embarrassed](/html/@6CEFBAD878A40FF337662307A879A7FD/images/emoticons/embarrassed.gif)
04-10-2010 4:21 PM
XP mode runs a full virtual (and licensed!) copy of XP within W7.
You do need the XP license as well though; 7 doesn't provide it.
04-10-2010 4:36 PM
Or you can use multi-booting.
04-10-2010 4:44 PM
i have the xp license i just dont have any back up discs
04-10-2010 4:50 PM
Give us a list of programmes that your concerned you wont be able to use going 64 bit and we will be able to help you In that query further please.
04-10-2010 5:24 PM
when i actually look at the programmes that arnt compatible they mostly look like they may have win 7 updates that may resolve the issue the one i was concerened about was the pre installed windows office xp pro that will need a paid update but i am now wondering if it was a legit copy installed on the computer and that is why they say a paid update as it seems unreasonable to expect to update office xp i may be wrong but everything about the shop i bought the computer from has not been great.............................. things like acronis true image is not compatible but as i have never used that programme it is not a great loss....
- « Previous
- Next »
