Don't buy a TPlink TD-9980 if you use Linux and
- Don't buy a TPlink TD-9980 if you use Linux and
10-12-2014 10:03 AM
The usb ports need a driver only M$ & Mac driver are available.
Tech help have been no help so far.
Re: Don't buy a TPlink TD-9980 if you use Linux and
11-12-2014 5:09 PM
A router isn't meant to be a print server as well.
11-12-2014 7:12 PM
It has been a while since I've connected a printer to the router, but I'm sure the router is just a thru device. The printer drivers need to be installed on the pc and then configure to use a network port.
This google search gives lots of hits, maybe one can help you
https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8&client=ubuntu#safe=off&...
11-12-2014 7:58 PM
12-12-2014 8:57 AM
And yes it appears as a usb port on the pc rather than an lpr queue like most routers.
Why do I want to do it, to be able to print from anything without the pc being on. That and the fact it is SOLD as having 2 usb ports for file/printer sharing. I don't use the file sharing I have a laptop doing that, but no spare usb ports on it.
12-12-2014 9:36 AM
I have a badge engineered model (without Linux drivers) but just use the actual manufacturer's.
12-12-2014 10:16 AM
12-12-2014 3:07 PM
It's very flexible and can work well on a small home network where a client taking exclusive control of the attached device isn't a problem.
It's an implementation of the KCodes system, so the issue is actually that KCodes don't offer a client for Linux...
That's why TP Link appear to be unhelpful: they can't directly help!
12-12-2014 3:14 PM
edit: looking in a bit more detail, it claims that the drivers are already in the Linux kernel.
12-12-2014 3:34 PM
Quote from: SuperZoom KCodes don't offer a client for Linux...
Quote The Kcodes’ kernel module utilizes 150KB Flash and 1MB RAM and it can be implemented on Linux platform in 2 weeks to meet today’s fast changing marketing demand.
According to that no real reason for them not to.
12-12-2014 3:47 PM
Might be economics; might be technical...
12-12-2014 4:46 PM
I have already complained about it, nowt else I can do until they get the finger out.
