Domain Removal
thejudge
Domain Removal
I had two .me.uk domains hosted by +Net. I let one of them expire in early June, as I didn't need it anymore. Nominet is currently showing it as 'suspended'
It's still showing in my list on the 'Domain Names' page. What do I need to do to remove it?
TIA
3 REPLIES 3
bobpullen
Fixes: 316
Re: Domain Removal
Raise a support ticket using the Help Assistant on our website and we can do this for you.
As far as I know there's no way to do it yourself via the Member Centre.
thejudge
Re: Domain Removal
Thanks Bob. Ticket raised.
thejudge
Re: Domain Removal
Sorted within minutes! Hooray for [CSA Name Removed] and all who work on Sundays!   Smiley
[Moderator's note by Jim (Oldjim)  Even when it is a deserved compliment ]
