Does anyone know what router settings I need for AppleTV Airplay? TG582n
- Does anyone know what router settings I need for A...
05-11-2014 7:50 PM
My Apple TV keeps cutting out when playing something from the internet (e.g. Amazon Prime video). Can anyone help with what router settings I need? I have a TG582n router from Plusnet.
I've got bored of constantly turning it back on! Please help!
Romilly
Romilly
1 REPLY 1
Re: Does anyone know what router settings I need for AppleTV Airplay? TG582n
07-11-2014 11:04 AM
Hi romilly,
Sorry to hear that you're seeing problems with the connectivity on your Apple TV, are you finding that this is only dropping when attempting to stream from Amazon Prime or are you seeing this across other streaming applications as well?
Also if you could confirm how the Apple TV is connected to the router, it should help us diagnose the issue for you.
