Does PlusNet block opening of ports on router?
- Re: Does PlusNet block opening of ports on router?
19-11-2015 12:55 PM
I've opened up the port (UDP 1194) in the "game and application sharing" on the default Thomson TG585 router.
However, I can't connect to it from outside.
The traceroute (below) indicates it is getting as far as PlusNet, but not to my IP, so:
- does PlusNet prevent you from opening these ports (and is there a way of getting around this)?
- or is the Thompson router just rubbish (as indicated in other posts!). If this is the case, I'll get something else, but want to make sure this isn't a PlusNet issue first.
~ $ traceroute -U -p 1194 212.159.xx.xx
traceroute to 212.159.xx.xx (212.159.xx.xx), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 3.650 ms 3.511 ms 3.332 ms
2 host81-148-96-1.in-addr.btopenworld.com (81.148.96.1) 28.594 ms 29.522 ms 30.032 ms
3 213.120.178.141 (213.120.178.141) 30.595 ms 30.431 ms 31.085 ms
4 213.120.177.98 (213.120.177.98) 33.178 ms 33.843 ms 33.692 ms
5 217.41.168.187 (217.41.168.187) 34.412 ms 34.261 ms 34.915 ms
6 217.41.168.107 (217.41.168.107) 35.822 ms 51.625 ms 51.596 ms
7 acc1-10GigE-0-0-0-5.l-far.21cn-ipp.bt.net (109.159.249.78) 51.274 ms acc1-te0-0-0-14.l-far.21cn-ipp.bt.net (109.159.249.88) 23.742 ms 109.159.249.68 (109.159.249.68) 24.157 ms
8 core3-te-0-0-0-18.faraday.ukcore.bt.net (109.159.249.41) 25.825 ms core4-te0-12-0-18.faraday.ukcore.bt.net (109.159.249.17) 26.640 ms core3-te0-9-0-19.faraday.ukcore.bt.net (109.159.249.39) 26.467 ms
9 peer1-xe-11-1-0.faraday.ukcore.bt.net (213.121.193.181) 27.335 ms host213-121-193-183.ukcore.bt.net (213.121.193.183) 33.967 ms 33.759 ms
10 195.99.126.183 (195.99.126.183) 33.520 ms 33.362 ms 33.201 ms
11 ae2.ptw-cr01.plus.net (195.166.129.4) 32.999 ms 33.724 ms ae1.pcl-cr02.plus.net (195.166.129.3) 30.916 ms
12 ae2.pcl-cr01.plus.net (195.166.129.6) 30.607 ms ae1.pcl-cr01.plus.net (195.166.129.1) 30.387 ms link12-central12.pcl-bng04.plus.net (84.93.249.118) 30.566 ms
13 * link12-central12.pcl-bng04.plus.net (84.93.249.118) 31.754 ms 31.596 ms
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
Thanks,
Jonny.
19-11-2015 1:05 PM
19-11-2015 1:17 PM
19-11-2015 1:18 PM
1. Have you turned off the Plusnet firewall (Settings in the Member Centre)? If you make a change here, you'll need to disconnect and reconnect for the change to have an affect.
2. How have you configured the IP address of the device on your LAN running the OpenVPN server? There have been issues with port forwarding not working to devices that have been manually configured rather than using DHCP. Try DHCP as a test and see if all springs into life.
HTH
19-11-2015 1:22 PM
@RobPN - Never seen those firewall settings before (!), but they're set to "Off" anyway!
Cheers,
Jonny.
19-11-2015 1:25 PM
19-11-2015 1:30 PM
19-11-2015 1:38 PM
19-11-2015 1:39 PM
20-11-2015 12:14 PM
Looking at that traceroute again though ^, the traffic reaches the Plusnet network and makes it all the way to the edge router where your connection is terminated.
This suggests that it's the router, port forwarding or listening device that's the source of the issue.
Presumably you did specify UDP rather than TCP when creating the port forwarding rule?
20-11-2015 1:46 PM
Yes, definitely used UDP.
I'm at work atm, but could provide a screenshot later?
Jonny.
20-11-2015 1:53 PM
My money is still on the DHCP issue but you seem to have discounted that...
20-11-2015 2:57 PM
20-11-2015 3:06 PM
I should have been more precise when I mention DHCP - The issue that's cropped up in the past is that Thomson routers don't seem to work reliably when setting up port forwards to devices that they have not issued the IP to. You may need to set your router up as the DHCP server as well in order to conduct your test.
20-11-2015 3:41 PM
