Do I need Adobe Flash with MS Edge in Windows 10?
- Re: Do I need Adobe Flash with MS Edge in Windows ...
28-05-2017 9:24 AM
Being a non-tech sort of person, I'm confused if I need Adobe Flash with MS Edge (or any browser) in Windows 10?
I note that sometimes the jigsaw piece comes up in the Edge top bar, so Flash is blocked.
Looking at the help below, I can turn it on and off.
However, when I went to one website, it needed me to download the Flash player to upload some photos.
https://helpx.adobe.com/flash-player/kb/flash-player-issues-windows-10-edge.html
So, do I need it? What does it do? Is it better on or off? Or am I just overthinking it?
Re: Do I need Adobe Flash with MS Edge in Windows 10?
28-05-2017 9:34 AM
Flash is moribund so I would say you can do without it. If you watch video on BBC or YouTube then they now support HTML5 but as to why that site needed it then I suspect its a bit of a throwback in need of an update.
28-05-2017 9:55 AM - edited 28-05-2017 9:55 AM
Grab a copy of Chrome as it has Flash built in and is kept up to date by Google for you as part of the browser updates. As it doesn't cost, there is no harm in having multiple browsers and just using the appropriate browser for a given website.
05-06-2017 6:59 PM
Flash was great when it first came out, as it filled a nice hole in the market (mainly to show videos). However, since then many security issues have been found with it, and (from my experience at least) it slows down / crashes the browser on a regular basis.
There are now many better technologies available - HTML5, as others have mentioned - and many sites will intelligently work out what you have and use it. And flash for mobile devices is no longer being developed by Adobe.
(native) iPhone stopped using flash some time ago, and Chrome will need you to "click through" to use flash.
However, there are many sites that have been "lazy" and have stayed with flash, and there's not much you can do, other than use another site, or whinge at them.
