Do AV impact on your PC
- Do AV impact on your PC
08-07-2015 10:37 AM
http://hexus.net/tech/news/software/84482-impact-security-software-system-performance-investigated/
Re: Do AV impact on your PC
08-07-2015 11:10 AM
York.
08-07-2015 11:13 AM
08-07-2015 11:31 AM
I switched to Kaspersky for 2014 and that was horrendous at PC boot up time. Gone back to the latest Norton Security 2015 and you wouldn't know it was there.
Also with Kaspersky I was always 2 Firefox versions behind whilst they caught up. Norton is on the ball and new Firfox versions never have any reported compatibility issues.
08-07-2015 2:21 PM
08-07-2015 7:46 PM
I'm just surprised it wasn't included in this article and wonder why?
York.
08-07-2015 8:52 PM
If only Apple would take a leaf out of Norton's book and speed-up the instalation of their PC software. Or are they trying to make it so slow and painful you'll give up and switch to a Mac?
08-07-2015 8:53 PM
I can't remember the details as it was a few years back
This is the link to the original review and earlier ones http://www.av-comparatives.org/performance-tests/
09-07-2015 5:49 AM
I 'think' Nortons strategy now is work off whitelists. Instead of performing the long, instrusive scan. They compare the file(s) against the whitelist for version, length and checksum which is considerably quicker.
NIS 2015 is a complete rewrite from the ground up and was possibly forced after the source code leak in India a few years back.
09-07-2015 7:29 AM
18-07-2015 10:27 AM
Never had a problem with it and absolutely no impact on performance.
Scan computer with malewarebytes and adwcleaner every couple of weeks and they never find anything.
