Diskeeper
Diskeeper
For some reason I've been on the Diskeeper email listing for years, but usually bin it (yes, I know I could have unsubscribed...but didn't) Just received the latest advertising their 2008 version.
Admit to being mildly tempted, but, is Diskeeper any good?
1 REPLY
Re: Diskeeper
Diskeeper is the best as XP's defrag is done by them. They were really the first ones to do it apart from Norton in the old days.
There is some other ones out there and some good free ones see
http://www.thefreecountry.com/utilities/defragmentation.shtml
Ultra is a good one.
