Disk needs to be checked.........
- Re: Disk needs to be checked.........
06-11-2010 4:27 PM
I Have had the following message appear several times during bootup,
Disk needs to be checked for consistency.
There is a item on the Microsoft website which suggests going into system tools,shceduled tasks and deleting either chkdsk or autochk.
Neither of these files appear in scheduled tasks.
Any advice where I go from here ?
Windows 7 32 bit.
Windows 7 32 bit.
We are born into history and history is born into us.
7 REPLIES 7
06-11-2010 7:48 PM
a read through of this chkdsk command information may help
http://support.microsoft.com/?kbid=831426
06-11-2010 8:06 PM
if everything fails
set the disk dirty check flag to off again by using
your Windows copy disk and when its loaded run the command prompt
then type
Chkdsk /f which starts up a run regardless of flag state to ensure that errors are fixed. the problem should stop after you manually run the command and let it finish once cleanly.
then type
06-11-2010 10:21 PM
Quote from: gleneagles I Have had the following message appear several times during bootup,
So you know this isn't a scheduled event, there is a real problem with your hard disc. Does the autochk process actually run? Does it finish successfully? Does it report finding and correcting errors?
07-11-2010 3:28 PM
I'm not convinced it's a hard disk issue as I have Windows 7 on 2 computers and both have come up with this message on the odd occassion.
After it's scanned through everything I don't get any messages that anything has been repaired and windows then continues to boot normally.
Not too clear on what you mean by using the Windows copy disk.........If I put this in will it not ask me if I want to reinstall windows ? or can I just ignore this and just type Chdsk/f and everything will run from there ?
The last thing I want to do is reinstall windows.
When you mention command prompt do you mean just type Chdsk/f in the run box.
07-11-2010 7:23 PM
---------------------------- first things first -----------------------------------
type regedit in the window just above windows desktop start button
to run the registry editor
click on its menu bar Edit>Find
paste the line below in the find what window
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager\BootExecute
look in the right window for BootExecute
right click and modify
then add new Value
autocheck autochk *
too add the line that you see in the photo
close the registry editor and reboot the pc
--------------------------------------done------------------
I was referring to running a command prompt from your windows DVD disk
from your DVD drive to reset the disk is dirty flag
then add new Value
autocheck autochk *
07-11-2010 7:40 PM
copy and paste the new line of reg data
dont type it
I think some closing program down from a disk operation has modified this entry wrongly
dont type it
08-11-2010 11:55 AM
Giro,
Thanks for the further info.
Will do as you suggest. I feel fairly sure some other program has reset something.
