Disconnection
mypyrex
Disconnection
Angry
I've noticed that every so often my broadband connection disconnects of its own accord. I find this quite annoying at times especially if I'm in the middle of something.
Does anyone know why it happens and how I can stop it happening. Angry
1 REPLY
mypyrex
Re: Disconnection
What modem/router do you use and how do you connect to it?
Intel(R)537EP V9 x DF PCI
Are you connected to the master socket (this is usually a two-part socket where your BT line enters your house) or to a internal extension?
An extension socket
Are your devices (including Sky boxes, fax machines, phones and the modem) filtered?
I've got filters on all phone sockets. Haven't got Sky or Fax
