Disaster PC cannot boot due to my stupidity
- Disaster PC cannot boot due to my stupidity
12-10-2013 11:46 AM
Don't ask me why, but stupidly I managed to delete the config.sys file and possibly one or two other files with zero bytes. Anyway, I now cannot re-start the laptop. I just get "NTDLR" missing" message. I assume it is because the config.sys file got deleted in error.
I am away from home and therefore have no Windows XP cd with me. Nor do I even have a bootable cd of any sort. If I could get the machine started back into Wndows, the deleted file(s) may either still be in the Recycle bin, or they may be able to be copied from a previous back-up of the system on the hard disk (can't remember whether I have one) or from Restore to Earlier Date.
I do have access to another XP computer where I am staying.
IS there any way of rescuing the dire situation ?
It is a complete disaster !
Thanks for any help.
Re: Disaster PC cannot noot due to my stupidity
12-10-2013 11:51 AM
12-10-2013 11:59 AM
Thanks for the reply. I could do that (I assume your reference to Linux was a typo and meant to say XP) but what is the best way way to create a bootable CD ? The problem is with my laptop. The other machine to which I have access is a desktop, but both computers are running XP ?
Your advice os really appreciated.
12-10-2013 12:09 PM
The easiest way to run an OS from a CD (albeit rather slowly) (which is what you need to do) is to use Linux.
Linux is also free.
12-10-2013 12:10 PM
Linux wasn't a typo but it is extremely difficult
Try this link instead http://tinyempire.com/notes/ntldrismissing.htm
12-10-2013 1:49 PM
http://pcsupport.about.com/od/findbyerrormessage/a/ntldrmissingxp.htm
I note the quote, "The most common reason for this [NTLDR is Missing] error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from."
Check your BIOS
Now take a look at this informative article on TechRepublic called 10 things you can do when Windows XP won't boot
http://www.techrepublic.com/blog/10things/10-things-you-can-do-when-windows-xp-wont-boot/348
From your description, I would try starting with the "Use Last Known Good Configuration" option first
12-10-2013 11:05 PM
So then I tried Old Jim's method using the tinyempire link. I managed to get the ISO file unzipped, and I installed the ISO recorder, but I could not get that part to work. It kept telling me that no recorder was registered, no matter how often I installed and uninstalled it.
Is it just a question of burning the entire ISO file which I unzipped ? Is there another way to burn this to a CD ?
12-10-2013 11:25 PM
This should give you a bootable CD.
13-10-2013 9:08 AM
13-10-2013 9:24 AM
Thanks for the info. I have been trying to make a XP CD boot disk but have not been successful in creating one, as explained above. All I want to do is to crate a boot cd which will let me in. It was easy in the old Windows 98 days but I do not know how to do it these days with Windows XP which seems much more complex. Any other suggestions would be appreciated.
29-10-2013 10:39 PM
Having got back home, I removed the hard disc of the laptop and installed it into my desktop with a USB interface. I then opened a back-up copy of my Windows set-up which I had stored on my desktop, and compared the contents of the root directory. Dozens of files were missing, files which I had not deleted, including NTLDR. I had only deleted one or two. Therefore my assumption is that the virus had done more damage than I was aware of.
Anyway, I copied the files from the back-up to the laptop hard disk, re-installed the hard disc back into the laptop, booted up and hey presto, all was back working again, thank goodness.
I checked again for any trace of the virus with Malwarebytes, tidied up the registry, defragged the disk and took another back-up to store externally.
The problem of course is that the System, Windows and Programme files are far too large to store on a CD or DVD. I have stored them on a 60Gb USB stick but it is dreadfully slow, as well as on the desktop. Are there any better ways of storing these files externally to be recommended ? The sizes are about 16 Gb and 8 Gb.
Anyway, thanks to everyone who tried to help. I am most grateful.
29-10-2013 11:07 PM
http://www.ebuyer.com/288344-toshiba-500gb-stor-e-basics-hard-drive-hdtb105ek3aa
Re: Disaster PC cannot boot due to my stupidity
29-10-2013 11:40 PM
Thanks. I think I will do that. It is not expensive. It is storage, but of course it can be over-written whereas a DVD / CD could not be.
