Disappearing programme
- Disappearing programme
04-08-2007 5:48 PM
I installed a touch typing course about 2 weeks ago. And although the start-up icon is on the desktop, and the disc is in the compter, it still tells me that the disc is not there and can't start -up. I can't find the programme listed and therefore can't unistall it and re-install it.
Does anyone understand what I mean and can help?
J
J
6 REPLIES 6
Re: Disappearing programme
04-08-2007 5:52 PM
Can you see the disk in My Computer.
04-08-2007 6:17 PM
Try ejecting the CD then putting it back and see if that helps. Let us know what happens.
04-08-2007 11:15 PM
Does sound like the CD is not being recognised. If you cannot access it via My Computer then check it does not have any smudges on the shiny side.
Try rebooting PC to see if it recognises it again. If not then you may have a duff CD or a duff CD reader.
05-08-2007 12:47 AM
Are you logged on as the same user as if you logon with another username the profile will be different and the program may not be there.
11-08-2007 3:01 PM
Thank you for all your messages.
J
It's a real puzzle. J
J
I am the only user of this computer.
Quote from: samuria Are you logged on as the same user as if you logon with another username the profile will be different and the program may not be there.
I've tried all that to no avail.
Quote from: Peter Does sound like the CD is not being recognised. If you cannot access it via My Computer then check it does not have any smudges on the shiny side.
No I can't see it listed in My Computer.
Quote from: Oldjim Can you see the disk in My Computer.
No,. That doesn't work either.
Quote from: God Try ejecting the CD then putting it back and see if that helps. Let us know what happens.
11-08-2007 3:04 PM
Does the CD work in another PC. If so then it could be your CD drive that is faulty or just has trouble with that CD.
