Disappeared Inbox. Help Please
Himself
I have an Apple iMac using Mail. I thought I was deleting an item in the inbox but unfortunately I deleted not just all the contents of the inbox but the actual inbox itself. Can anyone please tell me how to restore it?
1 REPLY
Fixes: 20
Re: Disappeared Inbox. Help Please
Not a mic user, but do you have a delete ditems on the mail menu (on Thunderbird it is called Deleted) if so have a look in there and see if you can restore it.
