Dirty Burners
- Re: Dirty Burners
Dirty Burners
10-03-2008 5:06 PM
I'm using ConvertXtoDVD 2.99.13.900 which has always worked well enough in the past.
The error message I get is:
write error at 2256(16) - code 03 73 03 [medium error, power callibration fail (CD Burner is dirty)]
Now I'm assuming 'dirty' means unclean in a 'dusty' kind of way which I'm hoping can be rectified easily.
Does anyone have suggestions as to how I can clean my 'dirty' burner. Is there a something physical I need to insert in the drive or perhaps a piece of software to run.
Maybe you'll tell me to stay well clear of ConvertXtoDVD.
Re: Dirty Burners
10-03-2008 5:31 PM
Re: Dirty Burners
10-03-2008 6:46 PM
Re: Dirty Burners
10-03-2008 8:33 PM
Quote from: HPsauce Given the price of drives I'd just buy a new one - under £30?
I think the OP would rather burn DVD`s than money.....
Re: Dirty Burners
10-03-2008 9:18 PM
Quote from: shutter I think the OP would rather burn DVD`s than money.....
Indeed. And he could well burn a lot more money trying to fix it, compared to replacing it.
Re: Dirty Burners
11-03-2008 4:48 AM
Maybe it's worth a try first if there isn't any chance of doing 'real' damage !
Re: Dirty Burners
11-03-2008 7:45 AM
Re: Dirty Burners
11-03-2008 9:08 AM
Re: Dirty Burners
11-03-2008 10:36 AM
Re: Dirty Burners
15-03-2008 3:47 AM
Having read another thread somewhere it was suggested that you tend to get rubbishy Discs at the bottom of spindles and I think this was the case.
Thanks anyway !
Re: Dirty Burners
18-03-2008 12:51 AM
Wow! I have never heard that one before, how is that supposed to happen then?
Re: Dirty Burners
18-03-2008 9:17 AM
Re: Dirty Burners
18-03-2008 9:54 AM
Quote from: God "rubbishy Discs at the bottom of spindles"
Don't ask me, it was something I read and it seems to be true.
I'm not complaining, it's saved me having to buy a lens cleaner and even a new drive which someone on here suggested.
The thread where I read this suggested that the manufacturers sometimes 'lose' faulty discs this way.
Re: Dirty Burners
30-03-2008 8:40 PM
Quote from: God Wow! I have never heard that one before, how is that supposed to happen then?
Early spindles of Discs would often have bad discs because the discs would rotate on the spindle scratching themselves with micro scratches, leading to failures. Nowadays they come shrink wrapped, so it's a lot less common, but it still happens.
