Diladele web security transparent ssl
- Diladele web security transparent ssl
13-12-2014 5:27 PM
Hi I'.m trying to setup Diladele web security with ssl bump at home to give me control over what the kids watch. I have got http working fine, however I cant get https intercept working. I get lots of errors like below
2014/12/13 17:09:44 kid1| fwdNegotiateSSL: Error negotiating SSL connection on FD 33: error:14090086:SSL
Has anyone managed to get this working on plusnet? I ask as one of the things that can break it is a transparent cache at the isp. So before I bang my head against the wall to hard, it would be nice to know if I stand a chance of getting it working or not.
7 REPLIES 7
Re: Diladele web security transparent ssl
13-12-2014 6:02 PM
I can't vouch for whether it will or won't work and I'm not really in a position to test it myself at the moment. What I do know though, is that we have a squid proxy on our network that's part of our IWF implementation .
13-12-2014 6:38 PM
I'm looking to implement the Diladele solution early next year, I'm just waiting for the immanent release of pfSense 2.2 - which will use a version of Squid that is compatible with the SSL bump feature needed by the Diladele software. Yes I could use the development version of Squid in pfSense 2.1.5, but I can wait for the proper release.
Have you configured your computer's network settings to offload SSL handling to the proxy, and installed the root certificates ?.
Having vaguely read the instructions, I'm not convinced that https will work the same as http through a transparent proxy without telling each computer that SSL is handled by the proxy instead of by the applications.
I've just noticed that there is a recently updated tutorial (I haven't read the updates yet), which you might find helpful - Filtering HTTPS Traffic with Squid on pfSense 2.1.5
I am not anticipating there being any problems over the Plusnet network, because https/SSL already works, and all this does is intercept the SSL endpoint so that the encrypted content can be analyzed and filtered accordingly by the Diladele software.
14-12-2014 7:03 PM
thanks for the replies, im pretty sure i have done the ssl bump correctly, but then it doesnt work so maybe I havent. Looking at the iwf stuff i shouldnt be getting proxied unless its a bad ip. I assume most arent so i think i need to play some more
17-12-2014 3:00 PM
Quote from: purleigh I'm looking to implement the Diladele solution early next year, I'm just waiting for the immanent release of pfSense 2.2 - which will use a version of Squid that is compatible with the SSL bump feature needed by the Diladele software. Yes I could use the development version of Squid in pfSense 2.1.5, but I can wait for the proper release.
cracked it and it works. It turns out openssl wasnt configured with any root ssl certs even though I had package ca_root_nss-3.17.3_1 installed it seems. Basically that just installs a couple of files ripped from Mozilla but doesn't actually integrate them into openssl.
I rather dirty hack fixed it but should still work going forward in that I just rsynced the following paths from an upto date ubuntu box
/usr/share/ca-certificates/ to /usr/share/ca-certificates/
/etc/ssl/certs/ to /etc/ssl/certs/
hopefully the added features of pf will handle this for you, but it may not
17-12-2014 3:30 PM
I'm glad you got it working !
Thanks for the update.
19-12-2014 10:52 AM
a tidier way to get the certs installed correctly
#!/usr/local/bin/bash
mkdir /tmp/.sslcrts
cd /tmp/.sslcrts
awk ' /BEGIN CERTIFICATE/,/END CERTIFICATE/ { print $0 }' /usr/local/share/certs/ca-root-nss.crt |
split -p "BEGIN CERTIFICATE" - tmp.
for file in tmp.*
do
mv -vf $file /etc/ssl/certs/`openssl x509 -hash -noout -in $file`.0
done
cd /
rm -fr /tmp/.sslcrts
mkdir /tmp/.sslcrts
cd /tmp/.sslcrts
for file in tmp.*
do
done
cd /
19-12-2014 11:06 AM
What are your initial impressions of "Diladele" software ?, is it worth the effort of installing ?
