Difficulty accessing external website
SwissRoll
Does anyone else having trouble accessing the Swiss federal government website at https://www.efd.admin.ch
It always times me out when I try connecting from my Plusnet account at home, on any machine I use. However I can access it from a neighbour's (non-Plusnet) account.
Of course I have already contacted the site manager. They are not (knowlngly) restricting my access to the site.
To track the problem further I need to know if it affects other plusnet customers or just me.
29 REPLIES 29
Legend
Fixes: 220
Re: Difficulty accessing external website
@SwissRoll - yes, times out for me too 'the site is taking too long to respond' being what I get as a response.
Try a tracert and see where it fails?
Works for me.
schant
I've had problems all week from my Windows 10 laptop accessing a variety of sites - timeouts etc. My Windows 7 laptop is fine. I wonder if it's something to do with recent BT maintenance work in my area? Have there been routing or DNS changes?
gleneagles
Aspiring Legend
Fixes: 17
Works fine and fast on my Android tablet
We are born into history and history is born into us.
SwissRoll
jab1: yes, times out for me too 'the site is taking too long to respond' being what I get as a response. Try a tracert and see where it fails?
SwissRoll: Tracert fails at the DNS lookup stage
John: Works for me
gleneagles: Works fine and fast on my Android tablet
SwissRoll: So clearly it isn't a general PlusNet problem. Something wrong with my DNS lookup configuration. Any suggestions?
schant: I've had problems all week from my Windows 10 laptop accessing a variety of sites - timeouts etc. My Windows 7 laptop is fine. I wonder if it's something to do with recent BT maintenance work in my area? Have there been routing or DNS changes?
SwissRoll:  This isn't a new problem, it's afflicted me for months.
ejs
Aspiring Hero
Fixes: 25
The site times out for me, and it does not appear to be a DNS problem.
traceroute to www.efd.admin.ch (162.23.128.213), 30 hops max, 52 byte packets
1 gateway (192.168.0.1) 2.697 ms 2 * 3 * 4 be3-3102.pcn-ir02.plus.net (195.166.143.132) 24.352 ms 5 195.99.125.140 (195.99.125.140) 24.972 ms 6 * 7 * 8 * 9 gen06are01.xe-0-1-0.bb.sunrise.net (212.161.254.191) 44.858 ms 10 194.230.36.210 (194.230.36.210) 44.884 ms 11 162.23.16.194 (162.23.16.194) 46.490 ms 12 gi03-bemon74isp-ipe1.inetbb.admin.ch (162.23.16.245) 44.501 ms 13 gi101-befll15a-sge-ice1.inetbb.admin.ch (162.23.17.250) 45.618 ms 14 * 15 * 16 * 17 *
SwissRoll
Yes, I've just tried again, this time got a DNS result (dunno what happened the first time), and the traceroute got as far as you did, to
 but after that .... silence.
SpendLessTime
Fixes: 86
@SwissRoll
I can connect quick happily to the site from a browser.
My traceroute is similar to yours (there is no reason why the target service would show on a traceroute as many websites block pings)
>tracert www.efd.admin.ch
Tracing route to www.cmsp2.admin.ch [162.23.128.213]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 * * * Request timed out.
3 2 ms 3 ms 3 ms lo0.central10.pcn-bng02.plus.net [195.166.130.249]
4 3 ms 3 ms 3 ms 411.be6.pcn-ir02.plus.net [84.93.253.79]
5 3 ms 3 ms 3 ms 195.99.125.144
6 4 ms 4 ms 4 ms 195.99.127.87
7 * * * Request timed out.
8 * * * Request timed out.
9 24 ms 23 ms 24 ms gen06are01.xe-0-1-0.bb.sunrise.net [212.161.254.191]
10 24 ms 24 ms 23 ms 194.230.36.210
11 27 ms 26 ms 26 ms 162.23.16.194
12 24 ms 25 ms 25 ms gi03-bemon74isp-ipe1.inetbb.admin.ch [162.23.16.245]
13 26 ms 24 ms 24 ms gi101-befll15a-sge-ice1.inetbb.admin.ch [162.23.17.250]
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
My DNS servers are Google Public DNS 8.8.8.8 and 8.8.4.4 using a Windows 10 PC
ejs
Aspiring Hero
Fixes: 25
I was using
# traceroute -q 1 -N 1 -T -p 443 www.efd.admin.ch
So it was using TCP on port 443 (HTTPS), the same as accessing the website in a browser would use.
Perhaps something along the route does not like my 146.198.X.X IP address.
DS
Champion
Fixes: 22
Failing via my dynamic 146.198.xxx.xxx IP too Huh
SwissRoll
Mine is 143.159.x.x, so that's not the common factor.
I'm not sure whether my IP is dynamic or static, is there an easy way of telling?
@SwissRoll - Login to your Plusnet account and you'll see it here, but if you've not paid for one I suspect not.
SwissRoll
That shows a box called "Connection Settings" full of little pictures ...
That's right @SwissRoll, so if you don't see one of these :
Static IP
then you have a dynamic IP. HTH
