Diary Application
- Re: Diary Application
Diary Application
04-04-2011 1:08 AM
I wish I had started this 30 or 40 years ago I have found some old diaries from the mid-eighties where I wrote some sketchy notes about feelings, troubles, girlfriends and the like which I've found interesting reads (my, how I've changed since then )
I could do it in Outlook but that doesn't have a search facility which I might need (not sure, though, having never done this before) or a method of protection from prying eyes. Also, I'm not certain how it would cope as the diary grows.
I've also thought of using Word but not sure if that is really suitable.
Has anyone cone across suitable sotfware (free or otherwise) that they could recommend?
Forum Moderator and Customer
04-04-2011 3:55 AM
http://sourceforge.net/projects/keynote-newfeat/
also available as a portable app
http://www.pendriveapps.com/keynote-nf-portable-notebook/
Something to get the ball rolling at least
04-04-2011 6:58 AM
a resume of free programs here http://ezinearticles.com/?Comparing-Free-Blogging-Software&id=41365
04-04-2011 8:55 AM
@pierre Not sure about blogging but will have a look.
04-04-2011 4:49 PM
04-04-2011 6:55 PM
Perhaps I'm over-complicating something that should be simple although I was looking for something that I could just click on a date for a new entry or review a previous one.
How have you done your diary in Word? I was thinking of a folder per year with sub-folders for each month and one word doc for each month. A bit unwieldy, perhaps...
I'm open to suggestions.
07-04-2011 9:31 AM
The document has twelve pages - one for each month. Each page has a table on it of only one cell deep and two columns. The reason that I use the table is to confine the month to that page. Then I just put the date in bold and carry on from there. I put birthdays and what-have you at the top above the table.
There's not much room doing it this way but it is only for basic stuff, although I understand that some people like to record their feelings about things and there's nothing wrong with that.
Oh, another thing is that it is password protected even though there's nothing much in it. At the end of the day I upload it to Humyo.com in case the computer goes down.
Have enclosed a bit of it for you to see. I am sure that others could do it better but this method has suited by simple requirements for a number of years.
