Dell Inspiron 1558 line in/Mic/Phone socket
shutter
Fixes: 65
The aforementioned machine, has only one phone socket.... and when I plugged in my phones before, it used to show a pop=up window asking what had been plugged in...and then the software would switch it to whatever use was required..
I don`t know what happened.. ....  maybe the bluetooth has stopped it ... but now I can`t use a mic or line in .. only plug in phones..  Cry
Anyone got any ideas ?  Huh Undecided
6 REPLIES 6
rongtw
Fixes: 12
Re: Dell Inspiron 1558 line in/Mic/Phone socket
did you try Hardware manager , see if its enabled .  or update drivers ?
HairyMcbiker
All Star
Fixes: 21
Sounds like a driver issue, check the driver from the Dell site.
shutter
Fixes: 65
Nothing showing in "Device Manager"    ...
(mic is enabled)..
Done all the updates that Dell had for my machine.. ( latest updates only a couple of days old)..
Re-booted and still no notification/choice pop-up window.
However... weirdly.... I have a radio that I take signals from and decode them using another program... and print it on screen through the "line in/mic" socket... ( which as mentioned is also the same socket for phones)..
I have two radios, and have made a double splitter box... so I can choose the line out  output from either radio and channel it to the laptop... I can also listen using same splitter box) to either of the radio`s by switching the "audio" output to phones plugged into the splitter box...
So... with an inline connector from the splitter box, I can pass the line out signal to the laptop...
. However, If I remove the phones from the other socket ( the audio output)on the radio splitter box,  the signal disappears from the line in....
(if I put a splitter on the laptop end I can faintly hear the sig by plugging in the phones to that splitter)... so the signal level is significantly lower. !.. not enough to be decoded by the laptop.
Prior to the present problem... it mattered not whether phones were plugged into the radio splitter box... the signal was always "good" at the laptop.
Perhaps I shall have to contact Dell direct, and see if there is some other driver that I need to replace/repair....
rongtw
Fixes: 12
Just had a quick google  Wink has your laptop have 2 headphone sockets lefthand side ??  and IDT HD sound ?
Most people had to unistall driver and reinstall to get it working
shutter
Fixes: 65
Erm .... no....  the clue is in the first line of my original  post  ! !    Grin
rongtw
Fixes: 12
Dooooooh  Crazy  my senior moment
