Dell C400 CD/DVD drives
Denzil
I've just bought myself a very cheap Dell C400 laptop. It was very cheap because it is missing a hard drive and battery. These machines have external optical drives which connect with a proprietary cable, which I will need to find to install an OS.
Does anybody know if the Dell cable uses the standard laptop CD drive connector, so any old laptop drive will fit, before I go and buy one? Ta.
Alternatively, anybody got a drive and/or cable (part 3G265) they want to get rid of? Smiley
