Delivery Dates
- Delivery Dates
Delivery Dates
23-09-2010 1:35 AM
I have ordered a plusnet package, is it possible to choose a delivery data for the router?
Also, I will be using a BT line rental, no actual home phone. Is this ok?
1 REPLY 1
Re: Delivery Dates
23-09-2010 10:09 AM
Hi, welcome the Plusnet and the Forums
The router comes out when the broadband order is accepted by BT so unfortunately we can't choose the delivery date. The routers come out First Class Royal Mail so will be held at your local Post Office if you're not in to accept delivery.
It's fine for you to not use your home phone, so long as you keep your line rental active. I would, however, recommend that you check your contact details here and make sure that we have a current mobile number.
