Deleting hibernate.sys
- Deleting hibernate.sys
24-01-2015 2:14 PM
Looking at Power Options > Advanced settings there are no options for hibernate under Balanced (Active), High performance or Power Saver.
If I run the Command Prompt as Administrator and enter powercfg.exe -h off or powercfg.exe -hibernate off I get the message "'powercfg.exe' is not a recognised as an internal or external command, operable program or batch file."
Meanwhile, I still can't delete hibernate.sys.
Any ideas, please?
Forum Moderator and Customer
Re: Deleting hibernate.sys
24-01-2015 2:22 PM
24-01-2015 2:23 PM
It should be powercfg –h off
24-01-2015 2:28 PM
24-01-2015 2:29 PM
@Oldjim I didn't think it made a difference whether adding the suffix 'exe' or not. But I tried without it with the same result
24-01-2015 2:35 PM
24-01-2015 2:45 PM
Out of interest, I forgot to mention in my OP that the Option for Hibernation is not included in the Start Menu.
24-01-2015 6:03 PM
Then in the command prompt do a 'cd \' and 'erase hiberfil.sys'
You may need to do an 'attrib -s -h hiberfil.sys' before the erase will work; not quite sure.
Then exit the command prompt at once before you accidentally type something else you regret.
24-01-2015 6:43 PM
Thinking about my reply #6 I went to hiberfil.sys Properties > Security > Advanced and selected Full control then Apply. Hey presto I could delete the file
I'll need to reboot a little later so will check to see if it's come back.
26-01-2015 1:59 PM
Edit: (Whereas powercfg -h off gave the syntax error message)
26-01-2015 2:41 PM
Following from my last message the hiberfil.sys file has not returned after a reboot so all seems good.
Thanks for all the help
