Deleting Windows Sidebar, and other Windows rubbish stuff
Fixes: 16
I have just tried to delete "Window Sidebar". from my C:/ drive.... however after the usual "warning" that "other progs may not run properly if I continue..." there appears another box with "you need permission to do this"...  so how do I get permission...?
Other "Bits" I would like to delete include
windows ....calendar
                      collaboration
                      journal
                      mail
                      photo gallery
                      sidebar.
by deleting the above,... I would gain almost 40Mb space for MY use and not taken up with stuff I don`t use....
any advice? on feasiblity.... risk.... and permission .... please.
Fixes: 62
Re: Deleting Windows Sidebar, and other Windows rubbish stuff
You would probably need to do it with administration rights
Which operating system are you using
Fixes: 16
Sorry ... shud have mentioned that.... Vista Home Premium
How do I get Admin rights?
Fixes: 62
The actual answer is that it is built in to the windows operating system and although disabling it is straight forward
http://www.howtogeek.com/howto/windows-vista/disable-windows-sidebar-in-vista/
Removing it is much less easy and is not recommended.
If you really want to - and I don't recommend it - there are instructions here
http://www.vistaheads.com/forums/microsoft-public-windows-vista-general/6803-uninstall-sidebar.html
I have to ask - are you really that short of space on your hard drive that 40MB would make the slightest bit of difference.
At risk of repeating myself - messing about with the Windows system files is not recommended and I personally wouldn't do it as you could easily finish up with a knackered system
Fixes: 16
Hmm... Thanks Jim.... looks like I will just have to "live" with the unsuable space !... will heed your advice and not muck about with it ...Shame...
(i do have the sidebar disabled)
Fixes: 24
Quote from: shutter
Exactly how small is your hard drive?  What percentage of this capacity is 40MB?
My prediction is that you will find this is less than 1/4000 of the total capacity.
Fixes: 16
My hard drive is actually 160Gb.... however 50% of that is dual boot with Linux Mint 10.... It is not just the amount of space... it is the "principle" of the thing.... why should I be hosting progs on my hdd that I do not want or need.?  and I should also be able to "dispose" of them without upsetting the OS...
Fixes: 24
Quote from: shutter
So 160GB x 1/4000 = 40 MB - I was spot on!
Quote from: shutter
Oh, but I didn't allow for that.  Shucks
Quote from: shutter
See http://www.amazon.co.uk/Dont-Sweat-Small-Stuff-Stuff/dp/0340708018 .  Maybe somebody can buy it for you for Xmas?
Fixes: 10
Quote from: shutter
Blimey, how do you feel about service packs and Windows updates then?
Steve
Seasoned Pro
Seriously okrzynska  and ReedRichards  can no one come on a forum for help any more without getting the 3RD Degree!!
If life gives you lemons, make lemonade.
Fixes: 16
Quote from: ReedRichards
Quote from: shutter
Quote from: shutter
Quote from: shutter
If this is the level of "expertise". then I feel sorry for any future "help" and "advice" you give out on the forum.....
To put it another way.... If you haven`t anything useful to contribute..............................................DON`T.... Thank you..
Fixes: 16
Quote from: okrzynska
Quote from: shutter
If Microsoft think that updates and bug fixes are important, then I see nothing wrong with installing them..... there is an intrinsic difference..... in case you hadn`t realised....
Fixes: 10
Fair enough Wink
Fixes: 24
Quote from: shutter
[If this is the level of "expertise". then I feel sorry for any future "help" and "advice" you give out on the forum.....
What I was trying to contribute was to reinforce the notion (already put forward) that the gain does not justify the work involved. Shutter, you may not be receptive to that idea but I tried.  I thought the original question frivolous so replied in the same vein.  40 MB of programs you don't want on a 160 GB hard drive is not a serious problem!
If you look in Control Panel under Programs you should find an option that says something like "Turn Windows features on or off".  I would guess that is where to look but I don't know for sure that turning off a feature wins you back the space it occupied on the hard drive and I don't know if there are options for all the things you want to get rid of.
Fixes: 16
My original question was not "frivolous", in any form..... it was a serious request for information, help , and advice...
which was very succinctly answered by "Old Jim",... and acknowledged in y reply number 4
« Reply #4 on 01/12/2010, 20:40 »
which if you had been "alert" and had read the whole of the post and response, then your brain would have assured you of the facts before you let loose your fingers on the keyboard.
Once again, you let yourself down in the "I know what I am talking about" department, where you indicate that I should use "control panel " turn off features... and then qualify that poor advice with
For somebody who tries to appear knowledgeable about computers,.... the above quote is indeed a shocking revelation.
and so, you did very little to reinforce any notions except those contained in my previous posting....
