Defragmentation - a few queries
- Defragmentation - a few queries
Re: Defragmentation - a few queries
09-11-2010 3:05 PM
Control panel
Power options
Hibernate tab
Uncheck Enable Hibernation
09-11-2010 3:06 PM
Quote from: jelv Defragmenting hiberfil.sys is similar to the technique for defragmenting large files using another drive.
1. Turn off hibernation so that the file is deleted.
This works in W7 or Vista.
It does not work in XP. You have to disable hibernation, reboot and the delete hiberfil.sys manually.
09-11-2010 3:12 PM
Quote from: shutter If I could find it. as the only location is C:\ .....
In Windows explorer Folder Options (in the Tools menu), View tab you'll probably need Show hidden files and folders enabled and Hide protected operating system files disabled to see it.
09-11-2010 3:17 PM
Control Panel
Power Options
Choose when the computer sleeps
then you are presented with two options (for laptop) battery and mains
drop down menus give various times, and eventually "Never"..
that was selected in my mains power.... but not in my battery power.... (now changed that to "never")
Do I have to re-boot now?
@jelv.... that is already checked.... to show hidden files.....
09-11-2010 3:20 PM
http://www.mydigitallife.info/2007/10/25/how-to-turn-off-and-disable-hibernation-in-windows-vista/
09-11-2010 3:27 PM
The only advantage with Hibernation ON... is when you use a laptop on battery, and it saves battery power.... then, say I was at a meeting, and did not use the computer for a while, then needed to refer to a previously uploaded page of info, the hibernation comes into use....
otherwise with it switched off.... I would still have to find an locate the page, ..... as I don`t use my laptop that way, I can see no advantage in having hibernation ON...
I can store a lot of pics, and music on 3Gb..... much more useful to me than being able to recall a page I was using half an hour ago.... !
09-11-2010 10:18 PM
In W7 you go to System Properties - Avanced tab. Click on Settings under performance then Select the Advanced tab.
Under Virtual Memory click Change. Make a note of the current settings then ensure Automatically manage paging file... is unticked. Then select No paging file. Reboot (this should delete the Page file), defrag then reset the Page file to it's original settings
Forum Moderator and Customer
09-11-2010 10:43 PM
10-11-2010 11:15 AM
All files, including hiberfil.sys and pagefile.sys, were completely defragmented using this option.
Its available here: http://www.iobit.com/iobitsmartdefrag.html
10-11-2010 2:11 PM
The win 7 completed. then when i tried to do the degfrag of 'free space' it hung.
The 2k8 didnt even finish, and hung mid-defrag i dont THINK ive lost anything, but still... not that impressed
anyone else had that ?
10-11-2010 2:29 PM
I tried Defraggler and was not impressed. So I tried Smart Defrag and have used it ever since - over 1 year now!
If you've never tried it then give it a go. See my previous posting fo the link.
10-11-2010 2:44 PM
Quote from: Matt_2k34 Ran Defraggler on a Server 2k8 machine, and a Win7 machine.
I always thought you shouldn't defrag a server
10-11-2010 3:05 PM
The drive in question is just a large storage drive, it is serving no "processes" so moving items around on it will cause no conflict.
and Fairenough, Looking now MrT
10-11-2010 3:12 PM
Quote Defragment server with Smart Defrag Server 2010, which works with Windows Server 2008/2003/2000 to highly improve server performance. Learn more
$80 for the privelledge... umm, no thanks
12-11-2010 3:14 PM
