Defining a COMPORT number on Linux mint 17 rosa
shutter
Fixes: 65
I am trrying to define a comport number through the terminal, using a USB to Serial Converter cable PL2303
This line seems to have a problem in it....
ln -sf /dev/ttyUSB0 ~/.wine/dosdevices/com4
It should be returned as a copy.. and the comport should be assigned to port number 4   However, I must have miscopied something... maybe the slants are the wrong way  (back slant )  ? ?   or spacing  but it gives the following error..
ln:invalid option - -`/`
Try `ln - - help` for more information.
However the help is incomprehensible to me !... can someone please correct it ?
14 REPLIES 14
Re: Defining a COMPORT number on Linux mint 17 rosa
Have you tried escaping the paths using single quotes? i.e.
'/dev/ttyUSB0' '~/....'
Also make sure that the device your linking to actually exists.
shutter
Fixes: 65
@Anonymous   do you  mean i should put the single quotes in where you have them on the existing format of the text?
I am not a Linux geek, so quite a lot of the linux terminology is not understood.
@shutter, Yes, like this:
ln -sf '/dev/ttyUSB0' '~/.wine/dosdevices/com4'
But this shouldn't really be needed so it tells me that something else is wrong.
shutter
Fixes: 65
ok thanks... wll give that a try... and then see if the "dosdevice" i.e. the pl2303 is correctly defined.  will probably take me the rest of the day... so don`t rush back ! !
cheers
Wink
@shutter, what you should do is :
cd ~/.wine/dosdevices
then
ln -sf /dev/ttyUSB0 com4
That should do the trick.
 Corrected typo spotted by @VileReynard
shutter
Fixes: 65
@Anonymous  ok thanks for that... maybe that line was missed out when I re-wrote the instructions ! .. will give that a go this afternoon...busy doing other stuff now.. helping a guy in Belguim with cwcom ! ( on linux ! )
cheers
Wink
VileReynard
Fixes: 20
Shouldn't
ln -sf /def/ttyUSB0 com4
be
and do you need root authority to do it?
HairyMcbiker
All Star
Fixes: 21
no why would you need root, ttyUSB0 should be user writeable, as long as they are in the dialout group
"hairybiker@octo:~$ ln -s /dev/tty0 ./com4
hairybiker@octo:~$ ll com4
lrwxrwxrwx 1 hairybiker hairybiker 9 Apr 2 12:21 com4 -> /dev/tty0
VileReynard
Fixes: 20
I see - note that
jeremy@hector ~ $ ls -l /dev/tty0
crw--w---- 1 root tty 4, 0 Mar 31 23:37 /dev/tty0
shutter
Fixes: 65
@VileReynard
@VileReynard wrote:
Shouldn't
be
I think you are confusing the issue even more... the original in my post was deV .. so why are you asking if deF should be deV?
As it happens,... the guy I was trying to help,. seems to have sorted it out... therefore, the original instruction that I wrote must have been correct, as it worked for me, on my initial trial... ( and I think it has worked for other Linux users since being published on the internet )..
Maybe, having already got the USB0  comport defined already,.. installing another usb to serial converter has confused the issue.. and I could possibly have mis - read the dmesg listings.
Thanks for your efforts guys.. ....   as usual.... much appreciated. Smiley
VileReynard
Fixes: 20
Linux doesn't come equipped with a /def directory. Cheesy
shutter
Fixes: 65
@VileReynard  so why did you post this, then ?
VileReynard wrote:
Shouldn't
be
@shutter, that was my mistake @VileReynard was only highlighting my error that I then corrected.
shutter
Fixes: 65
@Anonymous Ah, well... that explains why I was confused ! ! .. Undecided
@VileReynard restored to glory ! ! .. Wink
