Default Browser
- Default Browser
Default Browser
28-08-2010 8:53 PM
I've started to use SRIron as my browser instead of Google Chrome. When I installed it I ignored the option to make it my default browser (in case I didn't like it).
I do like it and when I open it up I'm asked if I want to make it my default browser, I select yes but it doesn't do it and every time I click a link in an email etc. the computer loads the webpage in Chrome.
I'm running W7 HP. I don't want to uninstall Chrome as I've a lot of bookmarks saved and, annoyingly SRIron will import bookmarks from IE and Firefox but not Chrome.
Any ideas?
Any ideas?
2 REPLIES 2
Re: Default Browser
28-08-2010 9:00 PM
try right clicking on the SRIron browser icon and select "Run as Administrator" then go to options and select "Make default"
try also doing the same with crome but deselecting it from making it your default browser
Re: Default Browser
28-08-2010 9:26 PM
That sorted it - thanks.
