Dedicated Stream PC
Mattz0r
Dedicated Stream PC
Hey Guys,
What are your thoughts on this: http://www.overclockers.co.uk/showproduct.php?prodid=FS-344-OE
Thinking about getting it, with an avermedia capture card, so that can I can capture HDMI, such as Xbox 360 and PS4 when I get one.
Reckon the specs are decent for the price?
Doesn't need to be mega powerful though.
Cheers,
Matt
15 REPLIES 15
rongtw
Fixes: 12
Re: Dedicated Stream PC
OC uk excellent place to buy from ,  Cool
VileReynard
Fixes: 20
A 1TB disk only costs £4+VAT more.  Cheesy
Mattz0r
Drive space isn't an issue,
I have 8.5TB of network storage on a gigabit LAN.
Razer
Excellent price. Is the power supply going to be enough? Seems a bit low to me. As to 4x, why not go 6 or 8x?
I'm going to have a look over the X8, see how the price of that works out, though it may well be absolute overkill for my meagre needs. Grin
Mattz0r
Not sure, I have a beefy PSU spare anyway,
CPU should be fine I think lol
Razer
That's what I thought when I bought a 4x a couple of years ago. It's never been enough. Sad
Razer
Can anybody recommend any other sites similar to overclockers? They don't have the case I want Sad and don't know when they're going to get more stock. Huh
rongtw
Fixes: 12
i use these also  Wink
http://www.scan.co.uk/
http://www.cclonline.com/
http://www.aria.co.uk/
hope you find what your looking for  Cool
w23
Fixes: 4
Quote from: Razer
Can you say what case you're looking for?
Call me 'w23'
Razer
@ rongtw. Already tried scan. Boy I don't like their website. I'll check out the others. Thanks for the suggestions. Smiley
@w23. Yeah, I want a system built with the Anidées AI-6B.
Amazon - http://www.amazon.co.uk/Anidees-AI-6B-Midi-Tower-Chassis/dp/B00681PHDA  ?
Razer
Yeah, I know I can buy the case in various places. What I'm looking for is a site that will build a system for me (like overclockers), but never having had a site do it before I don't know who is reliable. So I was looking for other recommended sites that build. Thanks, nonetheless, Purleigh.
rongtw
Fixes: 12
this place has your case  Wink  maybe give them a call they build to any spec,s , a friend recommend them
http://www.falconcomputers.co.uk/custom-built-gaming-pcs
Razer
Thanks rongtw, I'll check them out.
